Don't people check those things
http://go .reuters.c om/newsArt icle.jhtml ?type=oddl yEnoughNew s&stor yID=131321 37&src =rss/oddly EnoughNews
Seriously, How does a door just "fall off" during flight?
Wes C.
Light travels faster than sound. That's why some people appear bright until you hear them speak.
RE: Don't people check those things
they don't "just" fall off ... i suspect that the door in question has stops intended to react outward pressure only (as ou'd expect from cabin pressure). then there'd be a fitting so that the door doesn't fall off under its own weight. if this isn't maintained properly the door could come loose.
but there'll be a whole safety board analysis of what happened and why.
Wes C.
Not so with modern designs and smaller airplanes.
