vb/macros
vb/macros
bigb (Visitor) Jan 24, 2002
Hi
when I run my macro for excel in Visual basic I find this error:
Runtime error 1004
Method 'Range' of object' - Global' failed
I think the error is in this statement:
y = funct("abc", Range("abc"), 1)
The function has been defined as follows:
Declare Function funct Lib "hello.XLL" (ByVal sheetName As Variant, ByVal Range As Variant, ByVal lockFlag As Variant) As Long
Is range a predefined function which can be used in vb/macro
Range("abc") is supposed to calculate the range of the spread sheet "abc".
Could you help me fix this problem.
bigb
Hi
Runtime error 1004
bigb
RE: vb/macros
Best regards
Morten
RE: vb/macros
Thanx
RE: vb/macros
RE: vb/macros
Please post as a new thread and include some of your code. The ActiveSheet.Paste method is a valid method, so there is some other problem with your code.
bigb:
The Range object should contain a reference to a specific cell or range of cells.
Range("A1")
Range("A1:C55")
Hope this helps...
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
RE: vb/macros
RE: vb/macros
"Run-time error '1004': Unable to set the CenterFooter property of the PageSetup class"
prntaSheet.Activate
prntaSheet.PageSetup.CenterFooter = "STYLE 1 : " & estsrcSheet.Cells(5, 1).Value & ", " & estsrcSheet.Cells(7, 1).Value & ", " & estsrcSheet.Cells(9, 1).Value & ", " & estsrcSheet.Cells(11, 1).Value & ", " & estsrcSheet.Cells(13, 1).Value
If estsrcSheet.Cells(5, 10).Value = "yes" Then
prntaSheet.PageSetup.CenterFooter = prntaSheet.PageSetup.CenterFooter & Chr(10) & "STYLE 2 : " & estsrcSheet.Cells(5, 2).Value & ", " & estsrcSheet.Cells(7, 2).Value & ", " & estsrcSheet.Cells(9, 2).Value & ", " & estsrcSheet.Cells(11, 2).Value & ", " & estsrcSheet.Cells(13, 2).Value
End If
If estsrcSheet.Cells(6, 10).Value = "yes" Then
prntaSheet.PageSetup.CenterFooter = prntaSheet.PageSetup.CenterFooter & Chr(10) & "STYLE 3 : " & estsrcSheet.Cells(5, 3).Value & ", " & estsrcSheet.Cells(7, 3).Value & ", " & estsrcSheet.Cells(9, 3).Value & ", " & estsrcSheet.Cells(11, 3).Value & ", " & estsrcSheet.Cells(13, 3).Value
End If
prntaSheet.Activate
'ERROR OCURRS ON NEXT LINE
prntaSheet.PageSetup.CenterFooter = prntaSheet.PageSetup.CenterFooter & Chr(10) & Chr(10) & "Bid Provided By : Art's Custom Cabinets, Inc. - (559) 562-2766"
prntaSheet.PageSetup.LeftFooter = estnumLabel.Caption
prntcSheet.Activate
With ActiveSheet.PageSetup
.CenterFooter = ActiveSheet.PageSetup.CenterFooter & Chr(10) & "STYLE 2 : " & estsrcSheet.Cells(5, 2).Value & ", " & estsrcSheet.Cells(7, 2).Value & ", " & estsrcSheet.Cells(9, 2).Value & ", " & estsrcSheet.Cells(11, 2).Value & ", " & estsrcSheet.Cells(13, 2).Value
End If
.CenterFooter = ActiveSheet.PageSetup.CenterFooter & Chr(10) & "STYLE 3 : " & estsrcSheet.Cells(5, 3).Value & ", " & estsrcSheet.Cells(7, 3).Value & ", " & estsrcSheet.Cells(9, 3).Value & ", " & estsrcSheet.Cells(11, 3).Value & ", " & estsrcSheet.Cells(13, 3).Value
End If
.CenterFooter = ActiveSheet.PageSetup.CenterFooter & Chr(10) & Chr(10) & "Bid Provided By : Art's Custom Cabinets, Inc. - (559) 562-2766"
End With
