spec for fast machine for running wildfire 2
I have been using Pro-E wildfire 2 for 2 years now and I have been asked to get a good spec together for a new machine for myself.
Can you give me a list of the spec you would recommend including graphics card etc(I am running 2 screens)
DS
DS
RE: spec for fast machine for running wildfire 2
Good luck.
Jason Williams
K Development, Inc.
http
Dual Monitor Support
Limited dual monitor support is provided in Pro/ENGINEER Wildfire 2.0 on the Windows platform. PTC has successfully performed limited testing of some graphics card models from 3DLabs, ATI and NVIDIA that support dual monitor capabilities. If your graphics card is certified for Pro/ENGINEER Wildfire 2.0 and provides dual monitor support**, PTC expects that it will run in this mode without issue. PTC will provide limited support to resolve issues arising when running in dual monitor mode, however, the entire solution will not be submitted for formal certification as a complete configuration.
PTC has tested and officially supports the following graphics cards. This list is not meant to be a comprehensive listing of cards with dual monitor capabilities and it does not represent a shift from PTC's policy of certifying complete systems.
PTC's Support Policy.
Supported and tested graphics cards:
ATI FireGL XL1
3DLabs Wildcat VP 990 Pro
NVIDIA Quadro4 900XGL, 980XGL and FX 2000
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
