Error Launching Unigraphics NX 2
After installing the WGM for Unigraphics NX 2, I was launching NX and it is throwing me the following error.
UG/Open initialization failed
Waiting for UG/Open execute license to become available
Does anyone has any idea what could be the problem. This is happening while launching the Unigraphics.
Thanks in advance.
Deepak
RE: Error Launching Unigraphics NX 2
Sounds to me like NX is looking for a networked license for UG/Open and there either isn't one available.  How do you have your license server set up?  Is the license local, served or served and shared amongst other users?
In addition, what is WGM?  You may wish to provide a fully worded example before using acronyms in the future....just so no one gets confused.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Hi Tim,
My apology for uisng acronyms for the same. WGM stands for Workgroup Manager for Unigraphics. This is installed in the Windchill PDM system so as to integrate both Windchill and Unigraphics NX system and the user can directly check-in and check-out files into the Windchill system.
Well the license is installed in a different machine and I have installed NX on my laptop using the network machine. I am able to launch NX if the Workgroup Manager is not configured but when I installed workgroup Manager it fails with this error.
Please help me.
Thanks in advance.
Deepak
Do you have the UG/Open license configured on your laptop?
Ben Loosli
Sr IS Technologist
L-3 Communications
Hi Ben,
I donot know how to configure the UG/Open license. Is this the same as the default FlexLm license setup.
Here is what I did after installing the UG on my laptop.
Start Menu->Unigraphics->FlexLm Tools->License Options
->ADVDES
Here are the components of the ADVDES Bundle:
assemblies,
dotnet_runtime,
drafting,
dxf_to_ug,
dxfdwg,
features_modeling,
free_from_modeling,
gateway,
iges,
nx_freedom_1,
nx_freedom_2,
pstudio_cons,
pv_updatagenerator,
sla_3d_systems,
solid_modeling,
step_ap203,
step_ap214,
ug_collaborate,
ug_prod_des_advisor,
ug_smart_models,
ug_to_dxf,
ugopen_menuscript,
usr_defined_features
And I was able to launch Unigraphics after these configurations.
Is there any other configuration that has to be done besides the FlexLm license.
Please help me out with this.
Thanks in advance.
Deepak
Hi Ben,
Do I need to configure UG/Open license separately on the machine. If so how do I do it.
Please let me know. This issue is in a high priority status. Need to be fixed so donot know how to get this going.
Thanks in advance,
Deepak
There should be another line in your license file for the UG/Open license.
Look at the license file on the server and see what it says about UG/Open. It may be locked to a node or something else.
Ben Loosli
Sr IS Technologist
L-3 Communications
Hi Ben,
Here is what I have in my license.dat file:
VENDOR adamsd  /projects/cae5/vendor_data/adams/adams11/network/ultra
INCREMENT          ADAMS_OEM_KINEMATICS adamsd          11.0 15-MAR-2006   0 \
          EBBFC849C87A          VENDOR_STRING=MDI HOSTID=ANY SUPERSEDE       \
          ISSUED=28-FEB-2001
INCREMENT                     ADAMS_OEM adamsd          11.0 15-MAR-2006   0 \
          C386F54F1C31          VENDOR_STRING=MDI HOSTID=ANY SUPERSEDE       \
          ISSUED=28-FEB-2001
INCREMENT                     ADAMS_AMD adamsd          11.0 15-MAR-2006   0 \
          E8981D2F365F          VENDOR_STRING=MDI HOSTID=ANY SUPERSEDE       \
          ISSUED=28-FEB-2001
INCREMENT            ADAMS_OEM_DYNAMICS adamsd          11.0 15-MAR-2006   0 \
          E1968B511499          VENDOR_STRING=MDI HOSTID=ANY SUPERSEDE       \
          ISSUED=28-FEB-2001
INCREMENT             ADAMS_OEM_STATICS adamsd          11.0 15-MAR-2006   0 \
          59E88CDD343B          VENDOR_STRING=MDI HOSTID=ANY SUPERSEDE       \
          ISSUED=28-FEB-2001
Is this fine or there is some other information that is missing in this file.
Shall I send you the FlexLm log file for your reference. I have your email id.
Please let me know.
Thanks in advance for all your help.
Deepak
That covers Adams, not UGS products or PTC products.
There are other license files that have additional information on what license you have.
Ben Loosli
Sr IS Technologist
L-3 Communications
