entering xyz coordinatesat keyboard to draw line in soldworks
I am new to solidworks and while drawing lines using the mouse is straightforward, I have not found a way to draw by entering dimensions at the keyboard after selecting the line command etc.I could only modify coordinates after selecting object.
RE: entering xyz coordinatesat keyboard to draw line in soldworks
It sounds to me that you came from the days of AutoCAD. My advice to you, without sounding rude, is to get over it. The concept of sketching in SWX is completely different than creating geometry in AutoCAD. The sooner you forget about ACAD when working with SWX, the sooner you'll pick up Works and wonder why you ever used ACAD (other than the fact that it was the best of its time). To summarize the difference: in ACAD, the line controlled the dimension. In SWX, the dimension controls the line.
If you need the ACAD look and feel, you can turn on the 2D emulator in Tools --> Add-ons. This gives you the comfortable ACAD command line where you can use the famous @ symbol. I advice you not to do this, as it will only slow your learning of SWX.
--Scott
