VFD Application
VFD Application
I am trying to get more PSI out of a lube oil pump. The pump is running at 78 PSI. The motor is a 480 v, 47 FLA 40 hp motor rated at 3600 rpms. It is operating at 3525 rpms and 38 amps. I need approx 89 psi out of my pump, based on my calulations I need to drive the motor at 3772 rpms and 47 amps to get this psi. My question is, can I do this with a VFD? Will I damage my motor running it at this RPM?
RE: VFD Application
RE: VFD Application
RE: VFD Application
If the motor is running at 3525 RPM, it is operating at about 75% of rated torque. Rated torque would be 60 lbs-ft and operating torque would be 45 lbs-ft. If the speed is increased to 3772 RPM by increasing the frequency without increasing the voltage the motor will be capable of operating at about 40 Hp without being overloaded. At 3772 RPM, that would give you 55.7 lbs-ft of torque.
Assuming that you are driving a centrifugal pump, an increase is speed will require an increase in torque about proportional to the square of the speed increase. That would mean that you need about 51.5 lbs-ft of torque. Since that is 92.5% of the torque you should be able to safely produce, you should be OK. The motor should operate at not more than the rated FLA.
RE: VFD Application
At that point your load horsepower and the motor horsepower are equal and no further increase is possible. I am assuming that the pump flow rate is the natural flow rate of the system when you do this test. Depending on the pump design, lower or higher flow may throw this equalibrium point off so be sure the flow is where it normally would be.
You will not hurt the motor to do this within the limits we set above. In fact, you can probably go as far as 4500rpm with problems but you will likely run out of hp long before that. The motor will not overheat as long as the amps stay at or below nameplate.
This actually is becoming a fairly common method of optimizing motor/load behavior and is one of the nice benefits of operating with an inverter.
RE: VFD Application
Using a drive with Active Front End will help if this is not enough. Such units usually run at a higher DC-Link voltage than VFDs with diode Frontends.
LionelHutz proposal would be one option but it is quite expensive and exposes the motor to voltage stress it was not designed for.
One other common method is to reconnect a star connected motor in delta configuration but unfortunately the ratio you will get does not fit for your application. You would end up with the current beeing to high.
RE: VFD Application
This will boost the three phase voltage to 600 volts. You will be able to use a 600 volt VFD, and maintain the V/Hz. ratio.
Depending on the load, this would give you a little more horsepower than running at 480 volts. The motor should see about 514 volts at 3772 RPM. Not a problem as the V/Hz. ratio will be correct.
respectfully
RE: VFD Application
http:/www.jraef.com
Eng-Tips: Help for your job, not for your homework Read FAQ731-376
RE: VFD Application
First, a 40hp NEMA motor is almost certainly wired delta internally so changing from wye to delta is not going to be possible.
Second, by the time you buy autotransformers and a 600V drive, you've got to be awfully close to buying a 50hp 480V drive and motor and doing it the usual way.
Third, if I am reading the original post correctly (not always a safe assumption!) the poster was wondering what more he could get out of his EXISTING equipment since the motor was not at full load at base speed.
Finally, 460V 60Hz motors are, these days, under considerable stress to develop normal operating lifetimes as they are. Increasing the V/Hz curve upward to 500+ volts and correspondingly higher frequencies is probably going to cause short motor insulation life.
RE: VFD Application
Keith Cress
RE: VFD Application
RE: VFD Application
Anyone with an oil pressure gauge in their vehicle will not agree with you.
respectfully
RE: VFD Application
RE: VFD Application
Keith Cress
RE: VFD Application
Thanks. I made that comment instantaneously(by intention) but have been trying to find the logic behind that. Couldn't get any till date. Equally, I am not sure whether the oil pressure increases only due to acceleration in your example. I will look for the possible answers but I am lazy at the moment.
This is not to support my earlier post but to caution the future readers about my half baked idea
RE: VFD Application
A constant displacement pump, by definition, delivers a set volume with each revolution. The pressure is determined by the viscosity of the fluid and the restriction of the flow path.
The higher the flow through a given restriction, the higher the pressure. The higher the viscosity, the higher the pressure.
In an automobile, and many positive displacement pump applications, there is a pressure relief valve. When the relief valve opens the restriction is reduced and the pressure is limited at the pressure set by the valve.
As the fluid (oil) heats up, the viscosity reduces and the pressure drop across a given restriction decreases.
I appologise for my terse reply earlier. I have more time today.
respectfully
RE: VFD Application
