2006 Performance
2006 Performance
I just switched to 2006 from 2004. Working on the same stuff seems to take forever now. Has anybody else run into this?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: 2006 Performance
Try updating files with SW Task Scheduler.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
www.engtran.com
www.niswug.org
Ken
www.engtran.com
www.niswug.org
If you are using pdmworks you might want to take a look at this thread.
(not sure if any changes since the thread)
dsgnr1
Did you mean 80GB? 8GB isn't that big!
Run the conversion overnight or over the weekend. You don't have to you convert everthing at the same time ... do it in smaller batches.
It can make a big difference.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP4.0 on WinXP SP2
www.engtran.com
www.niswug.org
Yes the parts are converted when loaded, but only into RAM (Graphics and or physical). If the model is modified, would it not be rebuilt from the original file?
Jason
www.engtran.com
www.niswug.org
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
The result of the conversion was some speed up, but still not to 2004 levels on our drawings. In addition we have already seen at least one serious drawing bug in SP4.1.
www.engtran.com
www.niswug.org
www.engtran.com
www.niswug.org
Just out of curiosity, which SW version files failed the most or which caused the crashes?
SP4-bad experience
http:/
I noticed a bigger performance hit at home for SW06 than I did at work. At home I had only 512Mb ram and on smaller assemblies this wasn't a problem, but after upgrading to SW06, my home pc crawled on the same assemblies. After upgrading to 2 Gb, it worked much better.
Flores
SW06 SP4.1
