Solid Works Macro part.SaveAs2
OK, I think that with an example it will be clear:
t = Time
str1 = Str(t)
str2 = "C:\copy[" & str1 & " ].SLDPRT"
Part.SaveAs2 str2, 0, False, False
OK that doesn't work though checked with the QuickWatch and Str2 is a string and maches what I want. Such is this that if I change str2 = "C:\copy[ str1 ].SLDPRT"
it does save it with the new name.
Can somebody post me with what might be wrong?
RE: Solid Works Macro part.SaveAs2
What is an example of the desired str2?  If it is coverting it to a time, 12:45 for example, you will run into a problem with Windows based macines as the : character is not allowed in file names.
Eric
Thanks a lot. Yep that must be it. Thats propably why Date doesn´t work either "/" in 01/08/06
Once again thanks.
