Mass Editing of Properties
Does anyone know of a program/utility that will edit the SW Properties, in mass? Meaning, I can select a bunch of SW files, and add/remove/change any properties, and voila, away it goes.
I am aware of propagator, but I'm looking for others,
Thanks in advance,
Thanks in advance,
phreaq
Has anyone seen my brain today? (^_^)
www.phreaq.net
RE: Mass Editing of Properties
perhaps I didn't make myself clear. I dind't mean the mass, and in the weight of something, but doing a bunch of files all at once.
I guess the correct term is "en masse", but I couldn't figure out how to edit my post :)
phreaq
www.phreaq.net
We use Propagator at my company, but I know the task scheduler does it also...not sure how well though!
Boottmills![[soapbox] soapbox](https://www.tipmaster.com/images/soapbox.gif)
SW2006 SP3.0
I'm giving the task scheduler a spin now, but what about this scenario.
I have a property named "part number", an example value is "123-7654". I want to change the "123" to "456" but keep the rest, so the new value is "456-7654"
it seems task scheduler will not allow these types of changes.
phreaq
www.phreaq.net
http://javelin-tech.com/main/download/javware.htm
Any particular reason you don't want to (or can't) use Propagator?
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
h
It will allow you to bulk add, bulk delete, and bulk rename, one attribute at a time. It works pretty well, but doesn't go into configuration specific custom properties however.
If you feel bold enough to write your own macro (I did for the first time about 6 months ago) you should also check out ht
-Shaggy
After reading your last post, I think your best solution will be to write your own macro.
-Shaggy
as for why I don't wanna use propagator.... not sure really, just some of the guys I work with used it in the past and weren't too happy with it.
phreaq
www.phreaq.net
Check out the Batch rename in Solidworks tutorial at http://mountain-wave.blogspot.com/
The link is just below the last image on the page.
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
www.robrodriguez.com (updated 6/05/06)
SW 2006 SP 4.0
