Referencing Section Views
OK, I've seen this done a couple of ways, but don't quite remember them, know if there is a "standard" way. (Just FYI, using SolidWorks, and I'd think it'd be nice of it to put that type of note in as a feature when move the section views around.)
Cut a section, or make a detail view on sheet 1, put the section view/detail on sheet two. Best to cross-reference back and forth.
On sheet one, the section line has the A-A on it, and I can put a note under it stating 2:2A (or 2/2A) for sheet 2, zone 2A, or put in a box with a line around it, etc. On the section notes, can reference back to the calling sheet with 1:4B (or whatever). Is that enough? More info needed?
Thanks in advance.
Thanks in advance.
RE: Referencing Section Views
If it's the Move, you can use the regular cut-n-paste methods.
If it's the note, you have to add it manually.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
I know how to move, I know how to add the note, I was asking if below the Section cut line you would put:
SH 2, ZONE 2A
To reference where to look for the actual section view. And if do the same to cross-reference back to the cut. (Or detail) I've seen it as listed above, could be done with just "2:2A", or could be done within a block, something like:
CODE
| /| 2
| 2 / |
| / A |
|_/____|
I don't recall there being any specific standard in ASME Y14...
And just as an aside, I stated that it'd be nice if SW did the cross-referencing for you...such that when you move a view, the references would auto-update. I hate having to manually update things like that with "dumb" notes.
MIPOD ...
