GRIP Plot NX 3 problem
I copied the following bit of code from the UGS site to plot all drawings in NX 3(Note: I replaced their default plotter name with my hp1050c)
string/ dname(30)
        inextn/ &drwg
a20:    dname = nextn/ ifend, a70:
        PLOT/PRINT,'hp1050c',PROFIL,'<System Profile>',dname
            jump/ a20:
a70:    halt
However, I get the following error when I try to run it:
 Error 1549139 at line 5
 Unknown plotting printer, profile or group designation
It seems pretty straight forward. I don't know what I am missing. I am using UG NX 3.0.3.0 on Windows XP SP2.
RE: GRIP Plot NX 3 problem
Replace the '<System Profile>' with the actual name of a plotter profile stored on your system, something like: 'c:\plots\profile.dat'.
Ben Loosli
Sr IS Technologist
L-3 Communications
Thanks Ben,
I'm still not there yet. I have a printer directory on my C:\ that our UG admin must have set up. It contains a file called "BP.dat" that has very little info in it. It has another file named "defaultprofiles" that shows a list of all my available printers and plotter when I open it in Notepad.
When I point the program to either of these files (or others in the list) , I get the same error message as before.
I would try to look this up in the help files myself, but we got the wrong disc shipped with our NX 3 so I am flying blind.
I will keep screwing around with it and see what I can do. Thanks for pointing me in the right direction though.
