Electromotor Load Test
what is the better and easiest way for load test of a 110 KW
3ph electromotor.
RE: Electromotor Load Test
The standard procedure for such test is to couple the motors shaft to a DC-machine which feeds back the power to the line via a converter or motor-generator set.
