Force on Weir
Force on Weir
Force on Weir
For a "sutro" (or proportional) weir, how do you calculate the force on the weir "blades"? This is an outlet for a small lake, into a channel. Is it simply the hydrostatic force, assuming the water is flowing pretty slowly on the high side, or are there significant "nozzle" type or other forces to be dealt with due to hydrodynamic effects? Thanks-
RE: Force on Weir
Hydrostatic upstream and drag off the downstream face.
RE: Force on Weir
Thanks ron...is there someplace you could point me for figuring out the downstream face drag?
