"Hide" command missing from RMB menu in large assembly
I am working with a fairly large assembly, and when I click on a part either in the feature tree or in the model, my "Hide" option is unavailable.  I tried "customize" in the RMB menu to see if it had been turned off, but it still wasn't there.
When I open a subassembly, my hide option returns to my RMB menu.
I am able to hide parts by selecting them and clicking Edit->Hide->All Display States, but this takes a lot more time than I would like.
Any ideas?
RE: "Hide" command missing from RMB menu in large assembly
Maybe try exploding the subassembly that you're having difficulty with?
I have trouble with all parts and subassemblies.
Are you in "Large Assembly Mode"? Is your Assembly "Set to Lightweight"? Because this is usually when I have issues hiding anything.
Boottmills
SW2006 SP3.0
I was in large assembly mode and set to lightweight.  I turned large assembly mode off, resolved all components, shut down solidworks, and had the same problem when I reopened Solidworks.
Try raising the threshold of the Large Assy option.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Go to Tools\Large assembly mode and make sure that the Large assembly mode is not pushed in. If it is push it and Large assembly mode will be turned off. THis happens alot and is easily overlooked.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Turning large assembly mode off does not fix the problem.
Thanks for the ideas, though.
If you can open all the sub-assys & parts, and the Hide command is not hidden, then it makes sense that it is a Large Assy setting problem.
cheers
rlj4794 ,
Does the hide appear now?
Once you close and re-open the file (or SolidWorks), the Large Assembly mode will be re-activated unless you change your SW Settings.
Ken
No, that doesn't make it appear.
I tried an old version of the assembly and hide works just fine.  Something weird happened.
I think what you need to do is just reset your Toolbars completely. See Alternative reinstall in the FAQ of this forum. That will tell you what you will need to do.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Apparently this only happens in one configuration of one assembly.  When I switched to a different config the hide option reappeared.
