Ball of Wax
Ball of Wax
Ball of Wax
Hi all, I've got a bit of a challenge for you (I think).
We need to melt a large tote (big plastic cube) full of wax.  A heat wrap blanket was purchased to accomplish this, but the results were not acceptable.  The heating blanket took 5 days to melt the wax, when ideally, we'd like to have it melted in 24 hours.
Here are the vitals:
Volume of tote: 47.2" x 39.4" x 45.7" (1.39 Cubic Meters)
Weight of wax: 83 KG
Heat of Fusion (melting) for Wax: 34 Calories / Gram
Melting Temp of Wax: 27 to 32 degrees C
Specific Heat of Wax: 2.1 KJ/(KG*Kelvin)  (@ 20 degrees C)
Moloar Mass: 720 to 780 g/mol
Heating Blanket:
Wattage: 1440W @ 120VAC
Max Temp: 71 degrees C
Time taken to melt the tote of wax: 5 days
The tote has a large metal cage attached to it, so the hot blanket is not in direct contact with the tote.
It is proposed to replace the heating blanket with a hot box (essentially a large oven).  This oven would heat 2 totes at once.  Here are it's vitals:
Wattage: 9000W
Max Temp: 135 degrees C, plus a circulating fan to imporve convection.
Here's the question:
Can you prove, using appropriate formulas, that the hot box will in fact melt the wax faster than the heating blanket (preferably in ~24 hours).
Thanks in advance,
Adam
RE: Ball of Wax
Is this for a class?
What are the specifics for the fan?
TTFN
RE: Ball of Wax
Although it sounds like it, this is actually not for a class.  This is for a real life application at my plant, and the original configuration failed.  We must now "prove" that the proposed new method will work before we will obtain additional funding for the project.
As for the fan, I'm not sure of the particulars, but it is safe to assume that there will be slow moving air inside the hot box.
Thanks!
Adam
RE: Ball of Wax
Well, in both cases, the heat source was more than adequate to cause the wax to melt, so the main issue is that access to the heat for wax.  To that end, think convection oven and determine whether the fan is moving enough air for your purposes.
Note that the heat transfer coefficient of the moving air is driving the majority of heat transfer to the wax, so slow air is BAD.
Will the new configuration still have a cage around the wax?  if so, all the more reason to move as much air around as possible.
TTFN
RE: Ball of Wax
I don't quite understand the utility of this system/process.  There are a lot of ways to melt the wax.  It all depends on what the end result needs to be... i.e. quantity, time, efficiency, etc...
I2I
RE: Ball of Wax
If the tote is full of solid wax, the weight cannot be 83 kg. Is the molecular mass indeed 720-780 g ? Or is this a density figure ? This is apparently not a mineral paraffin wax. Can you enlarge about the chemistry of the wax ?
RE: Ball of Wax
Apparently, from the info given, the density of the paraffin is 59.6 Kg/m3.  Molar weight isn't relevant to the solution, although I think the following info is,
What's the starting temperature of the blocks and oven?
What's the heat conductivity of paraffin?
What's the maximum allowed temp of paraffin during the melt?
Is there a temperature control for the oven?
What is the oven temperature setting during the melt process?
What is the oven size?
Is it a well insulated oven?
Does the oven apply heat from the top, sides and bottom equally?
Is the liquid wax permitted to remain pooling at the bottom of the oven? (will the blocks of wax float on the liquid wax?)
What is the density of the liquid wax?
Clarify or confirm that each block of wax weighs 83 Kg and that 2 blocks of that weight will be melted simultaneously.
   Going the Big Inch! worm
http://virtualpipeline.spaces.msn.com
RE: Ball of Wax
BigInch, you are right. I wanted to have more information on the wax (for example, on scorching possibilities by high heat fluxes) before starting to attack the heat transfer problem.
BTW, the density of the molten wax would probably be lower than that of the solid block, thus it wouldn't accumulate at the bottom but float on top of the solid. Agree ?
RE: Ball of Wax
You're probably right.  I don't know the density of the liquid vs the solid, but as most substances arn't like water and it is less, it would fill up any void space around the solid wax block.
RE: Ball of Wax
Thanks for the input all.
I will try to have as many asnwers for you today as possible.
RE: Ball of Wax
Ok. Here we go...
The wax is a Polyethylene Glycol Monomethyl Ether (In the polymer family) Trade Name: PEG M750
Website for heating blanket:
http://www.briskheat.com/products/tote-wrap-around-heater.aspx
Website for Hot Box:
http://www.benkoproducts.com/hotboxes.html
The Hot Box:
(Qty - 6) 1.5 KW Electric Heating Elements - 3 on the right and left sides of the box
Blower can be 1020 or 2000 CFM located on the top of the box
There is an oven temp control - heat capacity up to 275F
Dimensions 111 3/4" Legnth, Height 66 3/4" and 63" Wide
Hot box will hold 2 totes at once.
The tote:
WIll still be caged
The mass was given from manufacturer of wax.
Density of wax 1.09 g/cm3 @ 122F
Viscosity of wax 32mm2/s @ 122F
If you need any more info. Just let me know.
Thanks again!
RE: Ball of Wax
Reid,  Still missing these.
What's the starting temperature of the blocks and oven?  Should it start at something like 70ºF, 20ºC or what?
What's the heat conductivity of wax?  As the edges of the wax heat up, some heat will be transferred into the wax block itself and begin to raise the temperature of the interior of the wax.
Assuming you don't want to smoke the wax, what is the maximum oven temperature setting you can have during the melt process?
RE: Ball of Wax
Upon making a rough estimation on about 1,350 (not 83) kg of waxy stuff one may arrive to the conclusion that your new arrangement would do the job as planned.
See please,
With the blanket, there was heat lost to the surroundings. Say, 1/3. Also assume (I feel biginch is averse to assumptions) 70 kcal/kg to cover for latent and sensible heat. Then,
[(1350)(70)]÷[(1.44)(0.65)(860)(24)] ~ 4.9 days
With the hot box and no heat losses:
[(1350)(2)(70)]÷[(6)(1.5)(860)(24)] ~ 1 day
Any comments ?
RE: Ball of Wax
I get 40 kcal/kg, assuming a 20ºC base temp and 32ºC melting point.
But, the big question is the heat transfer coefficient of the oven, given a best case of 2000 cfm and assuming a 6" clearance around the blocks, the air speed is 13 mph.  That results in a best case heat transfer coefficient of 20W/(m2ºC).
Total starting area is about 7.5 m2.  Assuming a deltaT of 100ºC and an average surface area of 2.5m2 to account for shrinkage, I get about 1.4 days.  To get a better area, you'd need to do the derivative and then average.
This all rather hand-wavy, since the melt has to go somewhere.  Is there a catch basin in the oven for this?  That'll affect the air volume, which affects the air velocity.
The max power is somewhat irrelevant, since the controller monitors temperature, not power.  Obviously, running the oven at a delta temperature of 200ºC would cut the time down to 0.7 days.
TTFN
RE: Ball of Wax
The correct mass is approximately 1518 Kg.
The whole application is indoors and starts at Room Temperature.
The max heating oven capacity is 275F.
Sorry, can't seem to find the heat conductivity.
RE: Ball of Wax
25362: What is the formula you are using?
RE: Ball of Wax
There is no catch basin. The tote is a plastic container (approx. melting temp of 350F) caged in by a metal frame w/ fork truck entry on the bottom of the cage.
RE: Ball of Wax
Oh, that means that the max air temp can't be much about 300F, so the max delta temp is only about 130ºC.  I get about 1.1 days at max air temp.
TTFN
RE: Ball of Wax
IRstuff, the molten wax transfering heat to the solid must perforce be warmer than the melting point. Reid2006 said up to 71 Celsius in his first posting.
The Cp of the liquid is usually higher than that of the solid, although polymeric solids may need some heats of crystalline transition. If I'm right, my assumption of 70 kcal/kg may be real. Do you agree ?
RE: Ball of Wax
Sure, but the Cp of the liquid is irrelevant to the melting of the solid.  The thermal conductivity might be more germane, but even then, the original heat blanket approach presumably had better thermal contact against the walls of the tote and took 5 days.  Doubling the delta T would only get you to 2.5 days.
That makes the thermal conductivity of the liquid rather poor, so the forced convection might be the only thing that gets you close.
Another approach might be to dig a few heater stakes into the bulk of the wax while it's in the oven.  This might even be done passively, e.g., with copper stakes or blades that have exposed fins in the air stream.
TTFN
RE: Ball of Wax
Hey,
This problem is actually my problem to solve. I work with Reid2006 and he came to you guys for me. So I decided to join, which makes things a lot easier.
RE: Ball of Wax
IRstuff, the sensible heat needed to heat the molten wax is also part of the overall heating duty.
Reid2006, there is nothing strange about my estimation.
Heat required to melt and heat the wax: say, 60 kcal/kg.
Amount of wax per block: 1518 kg.
Total heat required for 2 blocks: 60×1518×2 = 182,160 kcal.
Heating elements: 6×1.5 kW×860 kcal/kW-h×24 hr/day = 185,760 kcal/day
Time required: 182,160÷185,760 = 0.98 days
RE: Ball of Wax
True, but the given specific heat with a 10 ºC delta temperature is only 6 kcal/kg.  That's a long way from 34 kcal/kg.
TTFN
RE: Ball of Wax
Nevermind, I see what you did.
TTFN
RE: Ball of Wax
This is a unsteady state heat transfer problem with many resistances in series.
For given thermophysical properties of the wax, a higher ΔT and heating from all the sides would melt the blocks in a shorter time, since time is proportional to [(thickness)2÷ΔT]
RE: Ball of Wax
Supposedly, the heater blanket would have had that covered. winky smile
The main thing going here is that the delta temperature can be almost doubled.  But the calculations haven't definitely arrived at an answer that provides margin against the unknowns in the problem.
If the time is truly proportional to thickness2, the cutting the blocks into quarters with some sort of passive fin structure might provide sufficient margin against the time requirement.
TTFN
RE: Ball of Wax
Thanks all, you've been a tremendous help.
I have one question:
25362, how did you arrive at 60 kcal/kg?  Did you just work backwards from the known 1.44kw blanket for 5 days?
RE: Ball of Wax
Splitting the blocks into smaller pieces definitely decreases the melting time for convection as there would be a significant increase in heat transfer surface area.
I2I
RE: Ball of Wax
To answer my own question, working backwards using 1.44kw and 5 days, we obtain a heat of fusion of 97.9 kcal/kg.
(X Kcal/kg)*(1518 kg)= Y Kcal
(1.44KW)*(860 Kcal/KWh)*(24h)= 29721.6 Kcal/day
(Y Kcal)/(29721.6 Kcal/day) = 5 days
Y = 148608 Kcal
X = 97.9 Kcal/Kg
As originally given, the actual heat of fusion of the wax alone is 34 kcal/kg.  Quite a difference - due to losses I'm assuming.
So my REAL question is, should we use 97.9 kcal/kg as the "worst case scenario" heat of fusion, as demonstrated by the use of the heat wrap?
Also, is 70 kcal/kg a better estimate for using the hot box, as there will be lower losses and a higher rate of heat transfer due to convection?
RE: Ball of Wax
While your calculation is in technically error because you've not subtracted out the heat loss and the sensible heat, the number would be close to what you would use for the oven. The heat of fusion is still 34 kcal/kg.  If you had preheated your wax to just before melting, prior to measuring the heat input, that's what you'd get.
If you assume a 128ºC delta temperature in the hot box, the sensible heat comes out to 65 kcal/kg, which added to the 34 kcal/kg heat of fusion, gets you 99 kcal/kg.
TTFN
RE: Ball of Wax
I like the Cu or Al fin approach.  I used to melt a thick substance in a process.  We used an old industrial baking convection oven.  We set the SP about 50F below our smoke temp.
We had a large Al "X" that would fit in the container on the diagonals.  It was about 2/3 the depth of the box and it had 'wings' to keep it from sinking and keeping about 12" sticking up  for heat transfer.
We would just set it on top and fire up.  The X would sink into the material quickly.  We got more melting from the X than from the sides of the box.
We later went ot using metal containers with a light plastic liner in them.  This helped a lot.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
RE: Ball of Wax
Reid2006, my answer to the assumed 60 kcal/kg:
• latent heat of fusion: 34 kcal/kg
• sensible heat from 20oC to 70oC: 0.52×(70-20) = 26 kcal/kg
• total heat required: 34+26 = 60 kcal/kg
Cp = 0.52 kcal(kg.K), is an average I assumed for both liquid and solid wax.
To estimate times for heating or cooling such as in this case, the problem can be analysed by use of computer programs (which I don't have access to) or by use of diagrams for solid bodies of various shapes appearing in specialized books. One of them is fig 10.10 in prof. Aksel L. Lydersen's Fluid flow and heat transfer (John Wiley and Sons) ISBN 0 471 99696 3.
