Moving Dimensions
Moving Dimensions
Is there some to turn on a dimension when moving it? Everytime I move the dimension it turns into a box and it's pretty hard to manually algin with another dimension.
Macduff ![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2006 SP 4.1
Dell 380 XP Pro SP 2
nVida Quadro FX 3450/4000
RE: Moving Dimensions
Highlight all dimensions you would like to align and right click. The align comand has about 6 options for you to chose from.
Boottmills
SW2006 sp3.0
Yeah, I tried that and also works. It's a pain when you want to do a simple align manually. You see, I have this calibrated eyeball and........LOL!
I was just wondering if there was a checkbox under options I'm missing.
Thank you sir for your feedback,
Macduff![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Go Honda!
Didn't work sir. Still end up with a box when dimension is moved.
Colin Fitzpatrick
Is the box only around the number, or including the dim lines?
If including the lines, I have never seen that before.
If just the number, you need to align using the dim line either with snap or the alignment tool.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Don't we all have a "calibrated eyeball?"
Boottmills
SW2006 SP3.0
CTRL+Pick dimensions, then Tools > Dimensions > Align Collinear/Radial. I dragged that button to my dimension toolbar because I use it often.
Flores
SW06 SP4.1
