Demand Control System
I need to change my present INET Seven controller for a new branch one.
Could you recommend to me the best option?
I think that if we can use the most of the present components that will be better.
My applications are typically single/multizone air handling and both centrifugal and screw chillers.
RE: Demand Control System
Sorry but I have never heard of that particular system. Is it broke, obsolete or why do you need to replace it?
It sounds like you should talk to someone who sells HVAC temperature control systems.
They can look at your existing system, see what you are trying to control, and give you a proposal to install a new system.
Generally they will throw away much of the existing controls, because they won't warranty existing things.
S. L. Simon
