Etched foil heater
Etched foil heater
We have a project that requires an etched foil element, rather than our normal wire wound element (we make flexible heaters)
Does anyone have any ideas what calculations I need to switch to etch foil construction? If I could experiment, I could probably find it after several iterations, but we would be sending the artwork out for processing, so I want to get it right the first time.
RE: Etched foil heater
http://www.minco.com/products/heaters.aspx?id=409
TTFN
TTFN
