Non-Static Seals
Non-Static Seals
Alright, of all things, this is going to be used on a high-flow, quick opening outlet sealing valve, made for a recreational "toy"...
O-rings are, first off, the most obvious choice for a moving, (non-static), seal. But they usually require an accurately machined O-ring groove for them to actually work.
I have tried, (quite a few times), to cut grooves by hand, using guides and other techniques, and I haven't been able to get a good groove. I wasn't really suprised.
So I have been trying to find other ways of creating a moving seal. So far, I've got a few ideas, but I'd like to get some more input.
The seal would be on a moving cylindrical piston. This piston is a 1-1/4" coupling filled with fiberglass resin, which is housed inside of a 2" SCH-40 carriage, (tube). The wiggle room was originally pretty bad but I built up the O.D. of the piston by using more fiberglass.
My first idea is to just to use some 1/8" neoprene sheeting past the edges slightly to seal against the wall of the 2" carriage.
My second idea is really a question. Is there some sort of O-ring cutting tool that can be used without a lathe? You would have to buy one for every size O-ring you wanted, but I'd only need one. 1/8".
Thanks in advance for any of you help. I can't see any other ways then an O-ring or the gasket seal idea.
RE: Non-Static Seals
It seems that you are tempting the faith, eventually you'll come up with a drill and atempt to scoop the groove (on the piston?)with a knife or similar. Unless you use a precision cutting / machining tool for the groove, all you can achieve is a bicycle pump, at best.
Safer is to take your piston to the nearest workshop and pay a few bucks to have a proper O-ring groove cut (you'll save on medical bills).
Cheers,
gr2vessels
I have tried to find a gunsmith who would let me do it but again no dice.
The piston seal doesn't have too be 100% airtight. The seal is to improve the reliability of the equalization between the pilot valve, (behind the piston), and the pressurized inlet, which will allow the valve I'm building to be more easily piloted, (by a 1/4" Q.E.V).
Do you think the neoprene gasket seals at front and back of the piston would help in this sense?
The best method I've come up with for cutting grooves was to push a 2x1-1/2" bushing over the 1-1/4" coupling to the place I wanted the groove, use a small saw to cut to a depth of about 1mm, then use a triangle file to widen that, THEN use a normal edge of a sunflower bastard file to widen it and square it for the O-ring. I came pretty close, but it leaked at two locations when I pumped it with water.
Also, pressures in this device will not exceed about 80 PSIG. All components, (except the piston, which will be inside of a component that IS), are pressure rated by their manufacturer to far above this. I will, of course, hydrotest if I can find somebody to do it. If not, I know a way to do it with a grease gun, (of all things). You DEFINITELY want to test things with water before you pump compressed air into them.
Thanks for your help,
Mark
Cup seal, like in a bike pump,
Gland type packed joint
Or: buy a cheap hobby lathe?
Mike
http://www.gingerybooks.com/
http://www.lindsaybks.com/prod/index.html
and buy Dave Gingery's book on making your own lathe.
Mike Halloran
Pembroke Pines, FL, USA
