Drawing a measurment axis
Hi all,
I am working on a project where I need to draw a measurement axis (basically drawing a ruler) along an arc, with short marks in 1 mm increments and long marks and numbered every 10 mm.
Is there a function in Autocad (2007) that performs this easily? I've looked high and low, and can't seem to find one.
Any ideas are appricated!
Best,
Richman
RE: Drawing a measurment axis
You can use the "measure" command to put points along a curve and define the points to be look like lines.  Then you can measure the arc again using a block, then renumber the blocks' attribute.
You might want to use the array command
for all of the 1mm increments and then
a second array for the longer line at
the 10mm increments.
