Undercut Help
3
Undercut Help
Undercut Help
I need to undercut a shaft where it mates with the head. Is there an easy way to insert these undercuts or do I have to model each one.
In my MDT6 I could just insert an undercut to whatever standards I had loaded eg. DIN, ISO etc.
Any help would be appreciated
Nardac
RE: Undercut Help
Shaft? Head? What are you talking about?  Are you talking automotive or what?   If you explain a little more, we may be able to help you out; what are you trying to accomplish in other words.
Flores
SW06 SP4.1
RE: Undercut Help
Sorry, maybe my terminology should have been more precise.
I'm trying to undercut a 'shoulder', the point where one shaft diameter meets another on a turned part. This is common when one shaft diameter needs to be ground to achieve a surface finish or close tolerance, where a thread is present or for a bearing journal.
I hope this explains it a little better
RE: Undercut Help
There's no pre-built features for a shaft/head undercut.  However, you should be able to copy, then modify, the snap ring groove feature that comes in the design library to suit your needs.  Then you can drag and drop.  It should take about a 1/2 hour to modify and set up the design table for all your sizes.
TJ
RE: Undercut Help
An undercut feature would be good candidate for an Enhancement Request.
The simplest way is probably to do an extrude-cut using the face of the larger dia as the sketch plane, and use the edge of the smaller dia to offset a circle.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
RE: Undercut Help
Actually the simplest way (if you create the shaft with a revolve) is to include the undercut in the revolve sketch.
cheers
RE: Undercut Help
Thank all for your help.
Up to now I have created it during the sketch as CorBlimeyLimey suggests, but as I have a large number of shafts with different undercut forms I was looking to see if anything was built into SW that I didn't know was there to automate these.
I will try all your suggestions and see which works the best for me
Thanks again all
