Visulaizing two models in the same screen
Anyone knows how the results of two different Jobs under the same model can be visualized  in the same screen
RE: Visulaizing two models in the same screen
You can create another viewport and arrange them side by side. Also, with V6.6 you can link the viewport manipulations so that the different odbs rotate together.
Finally, you can create "overlap" plots of two or more. See section 36.6 of the ABAQUS/CAE User's Manual.
