Plotting Help
Plotting Help
Plotting Help
Hello - Just purchased a DJ 750C.  The plotter prints a test page fine, but can't get it to pring a CAD 2005 drawing.  It keeps trying to print to a plot file even though I don't have that option selected.  Below is the error message:
File: C:\Engineering Files\McQuay\Drawing Files\SITE McQUAY.dwg
Category name:
Page setup:
Device name: DesignJet 750C Plus C4708B.pc3 - plotted to file
Plot file path: C:\Documents and Settings\Glenn\My Documents\SITE McQUAY-Page 3.PLT
Paper size: ARCH D (24.00 x 36.00 Inches)
ERROR: Invalid Plot Information
Any help is appreciated.
RE: Plotting Help
The plotter itself is probably aligned to Plot to File, even though ACAD is not.  There should some way to reconfigure the plotter.
I have an HP, so the location & name of this are probably different.  But for an HP, select Plot, Printer/plotter Properties, Custom Properties, Ports.  Then, you can pick a Port, Plot to File, or AutoSpool.  I'd bet yours says Plot to File.  Pick a port, then you will probably have to align that port.
Engineering is the practice of the art of science - Steve
