Text in solidworks
Text in solidworks
Is there any way to insert text as a sketch in solidworks? I'm trying to do this as I want to export as an stl and then into some CAM software for cnc toolpaths. I'm trying to accomplish some engraving here. Thanks!
RE: Text in solidworks
However, it sounds like you may be looking for single-line, no thickness fonts. These have been discussed before on this forum.
See also, text, sketch in the Help files.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
I swear I looked through the help and menus and did not see it. Thanks a lot for the help.
I think we have a new acronym.
Windows XP / Logitech "Premium" Optical mouse
SolidWorks 2006 SP4.1 / SpaceBall 5000
Lava Lamp
www.Tate3d.com
I'm in assembly mode trying to use the hole wizard on a 1/8" inch plate(in editing mode) and I'm trying to line these up with a part already in the assembly. Is there any way to do this? The position tab of the hole wizard just ignores everything outside the current part being edited. Any ideas?
stupid.. uh .. I mean similar question.Helpful SW websites FAQ559-520
stupid... similar answer. Edit the hole sketch, move the points.Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
