Pressure Vessel for Liquid Ammonia
I have a question regarding Liquid Ammonia
Can any one tell me the properties of Liq. ammonia . At which temperature amonia is in liquid state . Furter what should be the requirements of making a vessel to store liquid ammonia . Is there are any particular requirements ?? If any one can share relevent literature that would be helpfull
Thakyou and Regards
Assad
RE: Pressure Vessel for Liquid Ammonia
The web site below is a good one for starters on handling ammonia. Your vessel will be a pressure vessel and as such needs to be designed to a recognized code of construction (like ASME Boiler and Pressure Vessel Code). Read up on this topic, it is very important to understand the hazards of dealing with ammonia.
http://www.osha.gov/SLTC/etools/ammonia_refrigeration/receiving/storage.html
I'm going on memory at this point, but all of the liquid ammonia preesure vessels w/o refrigeration) that I have designed per ASME VIII had an MAWP of 250 psig at a design temp of 150F.  I believe that most, if not all, were also PWHTd.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
I did a tank vent project some years back for liquid ammonia storage tanks at an ammonia plant, and I seem to remember them being the aluminum "Protectoseal" standard product.
http://www.protectoseal.com/
rmw
