create a part from an assembly
i know you can do it, and i forgot how.... sad
RE: create a part from an assembly
- Open the asm
- click the tab 'parts library' in the edge bar
- at the top left, click 'create in place'
HTH
Fred
Or if you're trying to make an entire assembly just one part, then open a new part and click 'insert' 'insert part copy'. Then navigate to the assembly.
Or if you are trying to make a part from an assy there is functionality within simplified assemblies to support this.
