CO2 from HCl and Bicarb
I am trying to find the temperature of the reaction if I mix 100 tonnes of 36%HCl with Bicarb. I have assumed 80.9 tonnes of pure powder. However I need to pump the bicarb so will probably go for a solution at a lower purity.
Can anyone help in trying to find the heat of the reaction. HCl and Bicarb will be at 5 degC.
Will mixing this lot cause the mixing chamber to frreeze?
RE: CO2 from HCl and Bicarb
If you "mix 100 tonnes of 36%HCl with Bicarb...80.9 tonnes of pure powder."
The heat produced is about 310 J/g, or 62 GJ (6.2 x 1010) Joules.
Doesn't freeze, at least in the conventional sense.
