Measure Thickness in v5
Using V5R16.  I've seen the Measure Thickness command available in R15 and R16, but only sometimes.  Is there a shareable product or a license I need to grab for this command to appear?  By default when I open CATIA, the measure thickness command is not available.  Help!
RE: Measure Thickness in v5
according to the help files; the Measure Thickness option is available with the DMU Space Analysis license, but only when the Shading With Edges rendering option is used.
