What's the difference between partial discharge and stremers?
Hello
Can you please tell me what's the difference between partial discharge and stremers?
Thank you in advance.
SamBones
RE: What's the difference between partial discharge and stremers?
Partial discharge is what happens in gas (mostly air) pockets inside an insulation system. It produces ozone (O3) and the ozone breaks down insulation so you get insulation breakdown after a few years.
Streamers are precursors to flash-over in air (or along a surface).  If you get streamers during PD test, you probably have sharp edges on bolts, wires, connectors etcetera.
Gunnar Englund
www.gke.org
Thank you skogsgurra
Sam Bones
