Materials for low concentration H2S Service
I am preparing to do a short term trial (3 days) of a new chemical in an existing process. The chemical is oil based and contains ~ 2 ppm residual H2S in solution. Temperatures and pressures are low (near ambient) and water content is very low.
Is this enough H2S to be considered H2S service?
The existing system is mostly SS tubing, however there are other pieces of process equipment (pumps, valves, and vessels) that are a mix of other materials including CS and rubber. Do I need to be concerned with 2 ppm H2S ?
Thanks for your help!
RE: Materials for low concentration H2S Service
Outcome?
