Pro/e Wildfire 2.0- Backup
Instead of using save or save as command, I have used Backup command to save a Pro/e part model in the same directory (saved as the same name).
After doing this when I open the model Pro/e crashes and I have to restart pro/e. Any ideas to check what is wrong so that this can be fixed.
Any help to fix this will be appreciated.
best regards,
ro
best regards,
ro
RE: Pro/e Wildfire 2.0- Backup
Why are you using Backup instead of just save?
What are you trying to accomplish by doing the backup?
Ben Loosli
Sr IS Technologist
L-3 Communications
I am not using PDM.
I usually save the file. Using Backup was a mistake which is proving to be costly now.
Back-up has just created new version files in your folder like this:
prt0001.prt.11
asm0002.asm.21
You can try to load in ProE the assembly with the version before back-up. In Win Explorer filter the files after the name and then erase the last top assy from the folder. Then load the assy againg.
If the problem is still there, then erase all the items with the higher number (ex: .11 or .21) and you will return to the state before back-up.
Before doing this, flush the content of recycle bin, so if you made a mistake you can easily find restore the part.
-Hora
