Pressure Cooker style seals
We manufacture various pressure vessels for industrial liquid filtration. In order to utilise a standard clamp arrangement and save some money I am looking to incorporate a Pressure Cooker style seal between the opening ferrules. The seal I'm imagining is a sort of v shape where by the internal pressure (10 Bar.G Max)would actually open the 'wings' of the seal against the ferrule faces thereby improving the seal. I'm pretty sure these would be available, but after a decent search of the internet I can't find anything suitable at the moment so I thought I'd put it out to you guys to see if you've come across this before.
The seal orientation would be like this (shown around cL)
Lee
Lee
RE: Pressure Cooker style seals
Advanced Products [Parker] has some too h
There's also the SAE -AS1895 metal "E" ring type
http://www.vossind.com/
I'm enquiring about these metal seals that you've told me of. This is exaclty what I was looking for but I was looking for rubber materials, EPDM and the like. But I'll see how I get on with these.
Lee
http://www.clampco.com/products/vband_stock.htm
http://www.nkrubber.com/gaskets.htm
