Tray Material !!
Tray Material !!
Is Carbon Steel material can be used for Sieve trays used in Extractor Vessel (LPG Service) ?? If yes what ASTM materail should be used . The tray support plates are CS , welded with CS vessel and trays will be bolted to the support paltes
Thankyou and Regards
Assad
Assad
RE: Tray Material !!
Also, ask your local rep of any tray supplier to send you a proper spec for the trays, they usually have free sets of comprehensive specs.
Cheers,
gr2vessels
