Flange & Flat Head Thickness of PV
Hi..
I am reviewing one pressure vessel design.Vessel is having two flat heads.Two slip on flanges are welded to shell.And flat heads are bolted to these flanges without gasket.Material of head and flange is same.
If head of thickness t is safe for this application,can i conclude directly that flange of same thickness t would alwyas be safe for such vessel?
If yes/no,How?
Thanks!!!
If yes/no,How?
Thanks!!!
RE: Flange & Flat Head Thickness of PV
There is no general rule: both parts must be checked against the applicable code rules.
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
