Looking for 10" to 4" pipe coupling
I have a 10" drain hub with a 4" sitting approx 2" inside the drain hub. I need to contain the material going into the drain so I was hoping to find a simple pipe coupling to place over the OD of the pipe and drain hub. I found this site but they do not have the size. The product is 250 degree steam. Thanks!
http://www.fernco.com/1056.asp
RE: Looking for 10" to 4" pipe coupling
You could use weld a 10" slip-on flange to the drain hub and weld a drilled 10" blind flange to the 4" pipe and bolt it up.
NozzleTwister
Houston, Texas
I think it would be pretty tough to contain the steam otherwise.
NozzleTwister
Houston, Texas
Try this.. http://www.linkseal.com/
Good Luck!
Hench
