Configuration problems
i have a question creating a configuration that uses the linear pattern command i can create the configuration no problem but when i change the configurations my linear pattern doesnt change anyone know a solution to this problem
RE: Configuration problems
Make sure the pattern is UNsuppressed in both configs.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Get the file here
http:/
Here is another link to the file. Mooload is screwy with our network settings.
http://
RFUS
This is how I normally do it.
http
http://
http://
The reason I would use this method is because I have never found a way to vary the direction of a linear patern between configurations. You can vary the distance and instances between configs, but as far as I know there is now way to flip/change the direction. Enhancement request time. Am I right or am I missing something.
RFUS
