generate dimensions
generate dimensions
generate dimensions
I tried to use generate dimensions on drawing from assembly.
The click on the icon was followed with ERROR TYPE=CATBASEERROR....ERROR NUMBER=131073 THIS HANDLER IS NULL...
I tried the example from help...it works...
Does anybody knows where could be the problem?
RE: generate dimensions
It's pretty hard to say - especially since you haven't posted your release and SP info...
CAD design engineering services -  Catia V4, Catia V5, and CAD Translation.  Catia V5 resources - CATBlog.
You're right...I normally work with R14...
I found out, that it works with R16...its time to upgradeclown
