Strain results
Strain results
Strain results
Hi all, i am currently working on composite analysis with Patran/Nastran combination...after running model i   obtain some strain values such as Component and Eng Component ..My question is that which one of those values is used for design allowables?...i mean which one i must take care on..As i know from theory Componnet value is two times of Eng component.. it means that if i make selection mistake i will be two times in failure region..i will be waiting your comments
thanks in advance
RE: Strain results
I assume you’re talking about laminated composite shells...
For a laminated composite, you probably want to look at ply level results.  You can get these from Nastran if you use PCOMP cards.  You define the properties of a single ply on a MAT8 card (2D orthotropic) and the ply stacking sequence on the PCOMP.
The ply strains in the element coordinate system would be eps-xx, eps-yy, gam-xy.  For a failure analysis, you really want the strains in the material coordinate system (which can be different for each ply).  These would be eps-11, eps-22, gam-12, and are used for failure analysis since the allowables are determined by testing in these directions.  Note that Nastran uses the engineering definition of shear strain.
In addition, Nastran can compute a “failure index” if you use PCOMPs.  A failure index of greater than one indicates failure, less than one is OK.  You have your choice of failure criteria (Max Strain, Tsai-Wu, etc), and you have to input the allowable stresses or strains on the MAT8 card.
This is just an overview.  For details, you must read the Nastran documentation, especially for PCOMP and MAT8.
