Line Sizing with Multiple Evaporators and an EPR valve
I was wondering if anyone knew how to or where I can go to learn more about sizing refrigerant lines for a refrigeration system using multiple evaporators and an EPR valve. (Upstream Pressure Regulating Valve) I have a system using 134a with one compressor connected to a chill box AND a freeze box. Any help would be appreciated! Thanks in advance.
RE: Line Sizing with Multiple Evaporators and an EPR valve
I'm not a real engineer, but I play one on T.V.
A.J. Gest, York Int./JCI
http://www.heatcraftrpd.com/service/handbooks.asp
This is zillionth time you recommending Trane technical books and do it one more time, you will be snapped with contempt of job(more specifically organization)
I think you are damn confident about your boss not visiting this site
