gear calculation
gear calculation
Hello everyone,
I haven't done this manually since I graduated. Is there anyone who can help me with this simple calculation, please?
Two screw gears that run together have radii of 6" and 8" respectively. The angle between their axes is 60 degrees and their threads make equal angles. If the gear of 6" radius has 36 teeth, calculate the normal circular pitch and the number of teeth on the gear of 8" radius.
RE: gear calculation
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
It's not a homework, I am trying to re-educate myself. Do you know anything about this kind of calculations?
Regards.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Thanks a lot for the useful links! You saved me hours of internet research I believe, thanks again!
