Why can't I delete unused levels?
I have been trying to get rid of "trash" in my drawings. I have cleaned up the drawing, but I cannot delete levels that are showing as "unused". I have several levels that are not used, and will not delete.
any suggestions?
any suggestions?
RE: Why can't I delete unused levels?
Maybe you can solve the problem as follow
find out where the elvel may be used
use key-in : LEVEL USAGE
then you see of a level is in used bij models, cell or dim Style
after that you can try : LEVEL ELEMENT DELETE
or LEVEL ELEMENT DELETE DEST:<level name>
with kind regards
If it is all that important, Key-in LEVEL DELETE. Open the key-in dialog and you can see what kind of commands are available, experiment with them and you will find out things without having to use the help menu. I have all my new techs look through the commands to get a feel for it.
Namdac
