PDM Works moving views
Drawings checked out of PDMW come in with misaligned views and sections. Any comments on this or anything relating to PDMW use. Thanks
RE: PDM Works moving views
What version?
I think 06 4.0 or 4.1 has some issues.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
We are on SW2005 SP5.0
Do not know of issues there. Is it all drawings or one?
Just your PC or others too?
Chris
AutoCAD 06
Are you sure you are not using Frist angle projections versus third angle projection? Thats not a PDMW issue, but a the way the drawing was made to begin with.
PDMW is just really for revision history and does not affect what the drawing has on it.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
My guess is that someone is modifying the views in the model. Try opening up the offending drawing as built at a known good revision. Let us know what happen as far as the view go.
Bradley
