Test results vs FEA results.
We wanted to study the variation of a gusset/rib in a clamp. We tested a sample and it was bend out of shape for a load of 200lbs. I need to redesign the geometry to improve the load using FEA.
When i modelled the geometry , FEA has predicting the stress to cross the yeild stress at 10 lbs at one point. and the stresses in the neightbouring regions gradually decreased to value much lower than yeild strength.
In such a case what should be criteria on stresses to decide the load for making the clamp to bend.
Is it I need to take the section at the highest stress point and take that load that makes the least stress in the cross section cross the yeild stress. I want to make a decission based on linear static analyis only as i donot have stress strain for doing non linear anlysis
Kamalakar.
Kamalakar.
RE: Test results vs FEA results.
Sadly I can't give you an answer, because I don't do stress analysis.
Cheers
Greg Locock
You will have trouble duplicating this test using purely linear, static analysis. As this object yields locally, the stress will redistribute. Linear stress will not properly redistribute the stress. If you look for "net section failure" (where the lowest stress across a section is yield), you will likely be conservative, but there is no guarantee.
You do describe If you refine the mesh in that area, does the stress level change much? Is the stress located at or very near a boundary condition? Is the yield point that you have in the model at or near the real-world yield point? There are many things that effect FEA results.
I have duplicated real world tests on many occassions...including non-linear situations. It isn't always easy, but it certainly isn't impossible.
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
Lower Alabama SolidWorks Users Group
corus
you know where the bracket failed (and where it didn't). why not add material where it failed (and remove material where it didn't, if you're picky about weight).
that, and a little (structural) commonsense should help.
btw, how much do you want it incease the strength of the part ? ... 10%, 100%. also, remember that this part is a component of a structure ... maybe strengthening this part might not be all you have to do (maybe the failure will migrate to the other parts of the structure). also, how well did the test fixture represent the rest of the structure ? maybe it was too stiff, causing the loadpaths to be not representative.
good luck !
Finite Element Analysis is faster and more accurate than handbook methods. CosmosWorks and SolidWorks are easy to use. However, there is a learning curve.
Finite Element analysis is accurate. However, assigning boundary conditions can cause incorrect results.
When in doubt, mesh fine. The only penalty is run time.
Your problem sounds simple. A FEA consultant might solve it for a reasonable cost. It is worth a quote.
Hope this helps.
"Finite Element Analysis is faster and more accurate than handbook methods"
Let's see, deflection of a cantilever. delta =W*L^3/(3*E*I).
I think we can assume that I'll have finished long before your FEA program has even launched.
"CosmosWorks and SolidWorks are easy to use." and like many easy to use tools are of limited use.
"Finite Element analysis is accurate." Yes, the solver accurately solves the problem you have set up. Whether that bears any resemblance to reality is another thing entirely.
"When in doubt, mesh fine. The only penalty is run time." No. The optimum mesh density is not infinite.
"Hope this helps. " well it made me grin.
Cheers
Greg Locock
But yes you are quite right, the statement "When in doubt, mesh fine. The only penalty is run time." is rather scary ! Throwing zillions of elements at a problem, doesn't automatically improve a simulation, or magically correct poor boundary conditions as the words of the previous poster seemed to imply!
Let me say that I've respected your comments in the other areas where you've addressed questions, but if you do you just lurk here to throw critical (not useful, just critical) comments out?
Garland
I once asked a young ME how his analysis results compared to a hand calc estimate and he was dumb founded that anyone would even consider doing that. His professors (apparently anyway) never taught him to question the results. I don't believe in the old adage to question everything-I could never see how you could actually accomplish anything if you questioned everything-but FEA results need to be questioned.
Bob
I'm all for hand-calcing, but some structures require a significant amount of simplification or an incredible amount of time to produce an answer that may suffer from many of the same problems found in FEA. I have a master's degree in structural analysis and love to analyze things, but I use FEA as a tool so that I can remain cost competitive. To date, nothing that I've designed using FEA has catastrophically failed, and tests tend to fall within 10% of my predictions.
I've seen many of those dumb-founded looks, but instead of criticizing the wearer, I prefer to educate them.
My background is that I worked in FEA for a few months, then switched to running a modal analysis lab, which is used to provide the FE guys with their primary correlation data. Since then I've worked in both fields off and on for 20 years. So, yes, I have seen many horrible things done with FEA, but /I/ don't do FEA stress analysis. Nowadays part of my job is to prepare the loads for static and dynamic strength analysis for components, but again, someone else creates and runs the models.
Cheers
Greg Locock
Careful now... If a tool is made easier to use, it is not to say that it is not capable. However chances of potential misuse increase because of the broader user base. I solved non-linear (material) problems with similar software which e.g. NEi will only be capable to handle in its next release (results compared favourable with Abaqus results).
"How many people will do the convergence test on their meshing before they reach the conclusion that mesh is fine enough?"
I'll dare to say I don't do this every time. Simply because one does develop a feeling & experience and it also helps if you understand the particular element formulation. Because of many other assumptions I also don't hunt the 3rd decimal.
I agree with most of GBor's comments. And, yes, it is extremely important to ALWAYS do hand-calcs; at least as a sanity check!
Kamalakar, consider using a non-linear analysis with bi-linear material model (a la corus). Alternatively linear calculated max stress values can be reviewed (lowered) using approximate plastic correction as described in the book "Practical Stress Analysis in Engineering Design" by Blake. It involves hand-calcs and is an estimate only.
Cheers
Gert
So add my '1' to Garland's '1' for a grand total of '2' who are admitting they do convergence checks every time. Of course I use a (h)p-version FEA code, and it's a lot more efficient and easier, not to mention one gets better convergence properties, than anyone using an h-version FEA code.
"they decrease the element sizes as much as possible .... in order to ensure it is convergent" - sorry but unless you actually do a convergence test it is unsafe to assume that your mesh meets the criteria. This is especially true with auto-sizing routines which I have seen throw 100,000's of nodes and elements unnecessarily into low stress regions, but still leave critical areas with too coarse a mesh, despite the massive size of the whole model.
Prost,
Very often it is not possible to locate a strain guage on the exact point of interest as indicated by FE. Photoelastic measurements can also have their problems (depending on the method used) in critical regions. For these reasons we also locate strain guages away from any obvious stress raisers in what we call field stress areas to assist in validating our FE models.
Photoelastic coatings work very well in many many cases. There is also a lot of research in thermoelastic measurement techniques that use infrared to detect tiny changes in temperature which sometimes can be correlated very well with strains and stresses.
Every measurement technique, as well as every numerical method, has problems, so I wouldn't discount any technique just because it has limitations, I would only make sure those limitations weren't distorting my results.
Don't have this article, otherwise I'd share it.
htt
http:/
GenRad or SDRC were promoting it in the late eighties.
Cheers
Greg Locock
"Finer the better" with H elements draws negative comments, However, I have not heard a refutation of this practice. In meshing finer and finer, I have seen a realistic appearing stress gradient change to a stress field containing spots of high stress that make no sense. This occured with a very fine mesh; (Global mesh/100)
In one reply, and in reality, inexpensive FEA tools are criticized as simplistic or useless. I never hear why, just that these are "toys" . Without naming names, I have seen excellent correlation between a lower cost and a higher cost package in a complex linear stress analysis of an assembly.
In the world that I have worked in for 30 years, engineers do not have master's degrees in engineering mechanics, and companies will not invest in the high end FEA packages.
Often, checking with hand calculations is not useful due to simplifying assumptions. Checking with a simple FEA model is one technique. Perhaps a more useful question than checking with hand calculation might be
"Did you do a free body diagram?"
There is a value in using FEA in that the problem must be defined. The user must think about the boundary conditions.
It is not difficult to program the code for doing a linear stress analysis without meshing capabilities. Actually, there exist free FEA tools which are far of being simplistic.
No, I said of limited use. Don't misquote me. I did not say they were toys.
Tell me, if they were as useful as full powered products, why would people pay for the full powered products? All you have to do is compare the feature-list, typically, to see what the differences are. At least one of the bundled products cannot handle any complexity in boundary conditions, and makes dangerous assumptions about them, and I doubt any of them can deal with assemblies.
So far as 'toys' go FWIW at home I do the vast majority of my FEA in the 200 node demo version of nastran for windows. And get very good correlation- typically within 5% of the correct (measured) static stiffness. But, I have full control of the model.
Cheers
Greg Locock
I think it is generally support. If you are only doing linear, static analysis, there are a variety of GREAT product ranging from free to $20k that will all do a great job, but if you have any questions about how to run them, the ones that cost generally come with better support.
Glad you added the word "typically".
There are a few that handle assemblies depending on what you mean by "bundled", what you are trying to do with the assembly, and how you create the CAD model.
I think the "moral" to this story is, "Prepare yourself with the knowledge of your own limitations and the limitations of your tools or those for whom you design your products may pay for it with their lives"
Garland and Greg, I personally think that you both hit good points.
While it's true that in the linear elastic, static, domain (and not only, I'd say...) the FE solvers behave all almost the same way (hopefully!!!), be them hi-end ultra-expensive systems like Ansys Multiphysics (but then, why get the Multiphysics license level if it's only for linear static?) or 100%-free packages, when it comes to capabilities in handling "exotic" boundary conditions then the music changes: for single example (and only to name systems I directly know or knew), up to v.2004 (and perhaps v.2005) CosmosWorks couldn't handle non-holonomic boundary conditions, while this capability has been existing in ANSYS at least since v.5.3 with COMBIN37 element. And the list could be VERY longer... Of course, the model you have to analyze can be as simple as you want, but as Greg says if you need a particular boundary condition and your package doesn't handle it, you'll have no chance to get any realistic result, I think.
