flow / velovity measurement
We are trying to get away from discrete alarming on Exhaust flow.  We have considered a number of options with analog transmitters, but I thought that I would through the this out there to see if anyone had any ideas / reccomendations.
the 2 meters I am presently looking at most are Dwyer:
http://www.dwyer-inst.com/htdocs/PDFFILES/cat/airvelocity/641_cat.pdf
http://www.dwyer-inst.com/htdocs/airvelocity/SeriesAVUSpec.CFM
as well as one from E+E Eleoctronics
RE: flow / velovity measurement
Oh yeah, some of the applications are somewhat dirty, and acidic
What is the purpose of getting away from discreet alarming? If you use an analog signal you will still have to set a limit at which the airflow is unacceptable. Unless you need a specific airflow reading at your monitoring station?? If this is the case, I would choose the 4-20ma output instrument, especially if the distance is long between the instrument and the analog input card.
yes, the Dwyer are 4-20, but they are 3/4 wire, and we want 2 wire.
We are a heavily regulated facility, and it has been stated that more precice SPs are required, and that exhausts will eventuall be mandated to have totalisers.
Review the exhaust conditions i.e. temperature, pressure and chemical composition. As with most regulated process you need to report SCFM * time to get to total CFM. The Dwyer probe you are looking at is for clean dry air at atmosphic pressure and is a single point in the air stream.  I recommend the use of a permanent flow monitor flow grid in the exhaust duct. I have used
  http://www.airmonitor.com/documents/process/brochures/BRO_LOflo_SS_12503800.pdf#search='Flow%20measuring%20station'
http://www.kele.com/olcat/F5/kms.pdf
You can get custom sizes. You need to determine the system accuracy and do a very good initial calibration that is traceable.
Take the delta p output to a transmitter with 4-20ma or 0-10v output. Various mfgs offer complete solutions with local display. It sounds like you are trying to reuse the existing 2 wire alarm system. If the wiring is your problem, you may want to look into a wireless solution.
http://www.kele.com/tech/monitor/Flow/TRAirFlw.html
http://www.lambdasquare.com/
