Simodrive 611 Help?
Simodrive 611 Help?
Simodrive 611 Help?
Looking for the exact configuration of the internal relay contacts of a Siemens' Simodrive 611 (digital) that control the power supply's go/nogo out put to the PLC.  Does anyone have any information on this?  I've checked at the Siemens' Power and Automation website, checked Doc on Web, and Doc on CD, and I still don't have a clue where or what exactly it is.  I am having a problem with a unit that had the main power supply changed out for a new one, and now am getting the error  to the PLC that is stating that the power supply is not ready.  terminal X111 (73.2) and (72).  It's a NO contact on 24V, and I need to find out what (exactly) controls that contact to find a fix to the problem.  Can anyone help me out?
RE: Simodrive 611 Help?
This is a language/grammar forum, you might try forum248 instead.
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Hey Fried!
You asked that question in thread248-161940 the 7th of August, and I answered it. You better keep track of your questions and answers!
Gunnar Englund
www.gke.org
Skogs - check out the posting times. thread248-161940 was started 10 mins after MadMango advised the repost.
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Steam Engine enthusiasts: www.essexsteam.co.uk
Yes, I can see that. Wonder if it helped to change the connection? No feedback yet.
Gunnar Englund
www.gke.org
