Formability of Cast 304
I currently have an assembly that requires a swaging operation on a wrought 304 part. Because of the complexity of the part, I've been asked if it can be cast rather than machined from barstock. Can I expect the same formability from a cast 304 part as a wrought 304 part? I don't want to compromise the ability to swage the part.
RE: Formability of Cast 304
Michael McGuire
http://stainlesssteelforengineers.blogspot.com/
mac, might the higher elongation of 50% require a solutionizing heat treatment (as per ASTM A351)?
Do you have typical elongation values from your foundries?
Michael McGuire
You need to watch the annealing practice. Good anneals and you should not have any problems.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Again, thanks to all for the responses.
