Pressure Reducing Station
Any online resources for pressure reducing stations?
I am curious as to how they work, and if they can reduce pressure to a set psi, or if it's just a set number of psi it takes off the head.
RE: Pressure Reducing Station
http://www.cla-val.com/Cla_TASeminars.cfm
Going the Big Inch!![[worm] worm](https://www.tipmaster.com/images/worm.gif)
http://virtualpipeline.spaces.msn.com
In the most basic ones, a small diameter lateral line acts on a diaphram. The diaphram has a spring providing counter force. The operator sets the range of motion of this diaphram by adjusting the spring tension. The diaphram acts on a valve stem downstream. The valve opens or closes as needed, and provides increased or decreased pressure drop, as needed.
Engineering is the practice of the art of science - Steve
