Can't use the /MAIL command! (Ansys 8.0)
Hi to all,
I'm trying to send an email at the end of an Ansys session with the /MAIL command, but the system tells me he can't find the attached file. I'm using Ansys 8.0, maybe this is the reason of this problem... Someone told me there is some configuration to do before using this command, but in the 8.0 help files (/MAIL command), there is no mention about any configuration. Here is the syntax of the command:
/MAIL, --, Address, Fname, Ext
Could anyone help me? Thanks in advance.
RE: Can't use the /MAIL command! (Ansys 8.0)
Hi
Usign the /mail commando:
If you are running ANSYS in a Microsoft Windows environment, you must configure BLAT (a freeware program provided with ANSYS). Before issuing the /MAIL command, enter this command from the C:\Program Files\Ansys Inc\V90\Ansys\Bin\Intel directory:
     blat -install smtphost.bar.com you@bar.comFor more information about the BLAT program, see the BLAT_README.TXT file in the same directory.
Grtz
Garry
