Tuning motorcycle carburettors
Want ways of tuning and getiing air fuel mixtures on inline constant velocity carburettors to there peak performance, without the aid of dyno.
Tuning motorcycle carburettorsTuning motorcycle carburettors(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Tuning motorcycle carburettors
I will take a wild guess that it is one carburettor per cylinder with IR manifolds.
Slightly cheaper option is one or two oxygen sensors and an exhaust gas temperature sensor on each pipe with a data logger. Move the oxygen sensor around for comparison tests to get a base line for the EGTs.
If you still insist on doing it like I did it in the 50's, try the local magazine/book store. There is enough on this subject to keep you busy for months! Reading plugs correctly is an easy thing to learn but requires LOTS of experience to be 'spot on'.
Rod
Does anybody no where the closest motorbike mechanic with a dyno to Gembrook, Victoria/Australia.
They have a dealer resource link on their page which should direct you to the nearest shop carrying their equipment.
That or find a local racetrack. Here in the states, you can often schedule dyno time on race weekends as at least one local shop will have one there.
Major motor cycle dealers should be able to advise.
Local race bike clubs should be able to advise.
The administrators at Phillip Island should be able to help.
Until I looked it up, I thought you must be out in the boondocks to even ask the question, not just out of Melbourne.
I have a small 8 chan data logging set up that I use to setup fuel injection bikes when custom tuning.
and have used it on the "older" stuff too
The racers I know running FI bikes are using mapping software with their Power Commanders, then verifying the bands through their practice sessions. Frequent dyno runs are a bit pricey for club racers w/o serious sponsorship, at least in this neck of the woods.
As an FYI for me, how much did your data logging combo set you back?
I guess my point is a dyno will tell you when your making peak HP, but Peak HP, comes in the "lean" area of A/F ratio
so you still need some sort of A/F metter with a Dyno to be safe. ( I tune Supercharged Mustangs, some with up to 40 psi of boost, small miscalculations can = many broken parts) with my setup I can look at EGT, Calculated A/F ratio thru the wide band 02, while changing the fuel injector pulse curve in real time (on a car anyway) the data logger works ok on a bike or for monitering on-going performance of a race car.
they sell products like what I have built myself
but they cost a whole lot more :)
Many think of dyno time as expensive yet they spend $500 on a pipe, $150 on a jet kit or $300 on a power commander and throw Shite loads of cash into polishing aluminum and painting body work. Then they say, $250 dollars to correctly set up a power commander or jet kit is too expensive.
Dyno time is cheap compared to what one spends on hot roddding and personal time testing on the street.
Additional note...your peak power will be found at 12.5 to 13.8 to 1. Not lean at all. Lean is mean is an old term and will lead to disaster. If you tune for peak power you will not be lean at all.
in a nut shell..your wrong and right, Peak HP will be achived at 14.7 to 1 A/F ratio the problem is we can not get a homogenous charge(fuel quality is another issue), but I do agree that the range you posted is the typical A/F ratio that most people find there
safe peak HP. on our race motor we have it dialed in to calculated A/F ratio of 14.1/1
street car: 89 Mustang 10.3 @ 132
Race Car: Mustang Pro Comp 6.45 @ 219
http://www.prnewsnow.com
Rod
Thanksagain for every body replying,
I have a dial carb balancer and all the carbs are balanced.
It is the air fuel ratio tha t is the problem because I have put pod filters on the carbies.
I have yet to find a dynotune place that is even remotely interested in answering my emails on pricing & when I could book it in!!!!
If you have a dyno with O2, you can test this for yourself. You’ll need an eddy current brake and real time torque reading or a least a programmable dyno to perform step and hold testing w/data logging. In my case, my dyno is programmable for step and hold, sweep and manual loading on the fly.
Otherwise reference:
The Internal Combustion Engine in Theory and Practice: Vol. 1: Thermodynamics, Fluid Flow, Performance
ISBN: 0262700263 Format: Paperback, 574pp Pub. Date: March 1985 Publisher: MIT Press Edition Description: Revised Edition Number: 2
Internal Combustion Engine in Theory and Practice: Vol. 2: Combustion, Fuels, Materials, Design
ISBN: 0262700271 Format: Paperback, 800pp Pub. Date: March 1985 Publisher: MIT Press Edition Description: 2nd ed., rev Edition Number: 2
These explain the curves of Air Fuel ratios and their effect on power production using very easy to read graphs including those showing combustion pressure and knock.
Sounds like you are in a tough place to get a good tuner. Keep hunting around to find a dyno with wideband O2 or 4-gas analyzer. That will get you tuned up right.
This means that if combustion is complete, all the fuel and all the free oxygen in the air is consumed.
In point of fact, the quality of the mix of air and fuel is never good enough for all fuel and all free oxygen to react or combine in the time the fuel mixture is in the combustion chamber and the piston is in a position to gain from the expansion caused by the heat of the combustion.
To get maximum power, you need to use all the air early in the power stroke so the pressure gets maximum exposure to the piston as it moves down. This requires extra fuel so there is a better chance of some fuel molecule being close to all the oxygen molecules, but not so many that it displaces to much air, or so that the combustion is so incomplete that soot deposits become a problem.
To get maximum economy you need an excess of air so that all the fuel is consumed, but there needs to be enough to sustain a stable flame front and to prevent free oxygen reacting with internal engine parts.
Only tests will determine the best ratio for either situation. Lots of interrelated variable exist that have an influence, including size and distribution of fuel particles, temperature of intake air, temperature of manifold and cylinder and cylinder head walls, air speed, shear in the airflow and turbulence, turbulence in the combustion chamber, combustion chamber size and shape, quality of ignition system, compression ratio etc.
We have dimpled our intake runners to create small eddy's
to help in A/F mixing and actually slightly reduce air flow
(Yates SB ford Heads -nascar take offs) that where opened up a bit much for supercharged use - the increased turbulance allowed us to tighten our A/F a bit.
some where I have the dyno data in excel there is no mistake in our gains in HP and torque
that said, I consider myself a good "Hobbie" tuner, better then most of the so called Pro's in the new england area anyway- there are not that many people out there with 1200 hp small blocks.
You asked "How is the best way to tune multiple carbs on my bike?" There followed a long laundry list of suggestions...ranging from mild to wild!
Dyno time is expensive...and subject to the whims of the operator! I found only ONE post by a gentleman who knew what was real!
Put a piece of plastis tubing in your ear...and synchronize bt the sound of the hiss! This will balance the airflows...and the mixtures to the cylinders. Then, play with the 'plug colors! Either use a "Colortune" sparkplug...or, there are lots of color pics on the 'Net / in books (remember books? LOL). Find your right colors, your right "hiss"...balance, and ride on! -whitevette
But by far the fastest and easiest way to synchronise four throttles is by eyeballing four mercury columns side by side. Very easy to make a multiple manometer. Once you have tried this, you will never do it any other way.
I've been at it a while and, yes, I have two water and one mecury manometers. The home made one is easiest to use and the mercury one is for fuel injections, it's not sensitive enough for carbs. Sorry to say, I still stick a piece of tubing in my ear and listen to the 'hiss'. Faster, just as accurate and pretty cheap. It's a learned skill...if you can do it, it's accurate. This method is just one of those tuning aids I learned before we all had to have computers and such. Some of this new hi tech stuff (not a manometer, I built my first one in 1957) that's necessary to keep modern cars on the road are great, don't get me wrong on that. I'm just getting to old to learn all these new methods. Guess I'm still stuck in the '80's.
Rod
Then you to a hard run at wide open throttle, cut the engine while there, and read the plugs. if you let the engine idle or drive slowly the plugs wont give the correct reading.
Ken
The dowel rod was small enough to fit inside the return spring(s).
Just as on my non-CV carb applications, low speed throttle response was increased dramatically, and the increased vacuum/flow signal over the needle jet required going one size leaner on the pilot jet.
It's worked on every bike I tried it on. The hole/slot in the bottom of the slide on non-CV bike carbs reduces signal strength over the needle jet.
On non-CV carbs I just put a rubber flap cut from an inner tube over the needle plate and let the return spring hold it in place.
