Nvidia shows Quadro Plex graphics system
I guess at the recent Siggraph convention Nvidia showed their new external box graphics unit.  The flash animation shows two racked together for 8 GPUs.
http://www.nvidia.com/page/quadroplex.html
RE: Nvidia shows Quadro Plex graphics system
So you would use this in a multi-user environment, and have 2-4 comuters hooked up to this and it would do the heavy lifting when it comes to graphics?
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
This unit has 8 VC in it and the cost is $18,000... i don't see many people upgrading to this thing.
regards,
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
This is designed to hook up to one computer (at least at this time).  So that one computer would have 8 graphics engines on it.  If you were in a company needing hi-res real time rendering or realtime animation then this would be the thing to have.  A bit expensive though.
For example, if you are designing cars then you could have the whole thing rendering in realtime at full size on a projector.
